In this report, we want to write a list of products with some product details (e.g. name, category, price etc.) using Word bulleting feature. Data model used for all examples is exposed here.
Initially, we are creating a report template. Follow the common preparation steps to start building the template from scratch:
  • Open a new blank Word document and enable it for templating
  • Turn on Data Sources and Elements Explorers
  • Define default data source as the Product class
After that, you should be at the following point:
Repeating arbitrary content image
We should emphasize that we want to build the template binding LD Elements to a list of Product instead of to one single instance of class Product:
In the Word document (template) insert a bullet and while it is marked, insert a LD List element. Bind List element to default data source that represents collection of products leaving the Path property empty:
Set the sorting of the future rendered list of products through Order By property of the List element (about sorting collections you can read here):
Within the List element insert two LD Field elements bound to Category.Name and Name properties of class Product, a type of IEnumerable<Product> (binding source of their parent List element):
Finally, finished template (with Design Mode switched on) looks like:
Next, save the template and generate the report. Report generation takes place programmatically, from your application that is using (has a reference to) the LD ReportEngine dll. This code looks like following:
// Instancing report engine, by assigning the data source
DocumentGenerator dg = new DocumentGenerator(DataAccess.GetProducts());
// Generating report by specifying the report template and the resulting report (as file paths)
DocumentGenerationResult result = dg.GenerateDocument("example7.docx", "example7_output.docx");
// Examining potentially errors
if (result.HasErrors)
    foreach (Error error in result.Errors) Console.Out.WriteLine(error.Message);
It is also possible to invoke the method GenerateDocument with same parameters typed as System.IO.Stream.
Generated report looks like:
