Troubles with listControl after updating to Version 3.0
luna posted this 09 October 2015
Hello!
After updating to Version 3.0 I encounter problems with the listcontrol.
If I add a field to the list following error pops up
Docentric Error
My xsd-schema for the list ist defined like this
xsdschema
In the prior version no problem.
When I open an old report with a list following error occurs
docentric
errorwithold_reports
What I'm doing wrong?
I've tested the fixed version (.... and removed the double root elements ;) ) and now all works fine. Thanks for your promt help and keep up the good work.
8 Points
2 Comments
jles posted this 12 October 2015
In order to reproduce this issue on our side we would need the template and the XML file. But before doing it I suggest you to try the newest version 3.1 which is not public yet, but stable and I think it already contains the fix for your issue. I will send the link to your email.
Best regards, Jure Leskovec
jles posted this 14 October 2015
The issue is now fixed. Version 3.1 contains the fix.
