Table row height
danvonfeldt posted this 13 September 2017
Is there a good way to control the height of a table row? I'm running into issues where I have lots of lists and tags which is bloating the height of the table row. The only way I am seeing around this is to design it and then turn off tag view and slide row height grid line. I'm wondering if there is another option.
Thanks!
29 Points
3 Comments
jles posted this 13 September 2017
Hi Dan,
You can always bring up the Table Properties window, go to the "Row" tab and specify row height there. Would this work?
BTW, if tags are visible they only temporarily/visually distort the layout. After you generate the report, the result should be ok.
Regards,
Jure Leskovec
I can't have a static row height, so setting the row height is not an option. I've attached some screenshots of what I have if that helps you with thoughts/ideas.
https://ibb.co/jYCWWv - design mode
https://ibb.co/jkN9Ja - generated
29 Points
Can you share your template and the generated document? Of so, just attach them to your email. If not, can you send them to "support at docentric dot com"?
