Subdocument contains image
jrousselle posted this 13 January 2014
I try to call as template with a subDocument.
If this subdocument contains an image, this picture does not appear.
Can you help me ?
11 Points
18 Comments
jles posted this 13 January 2014
Hi jrousselle,
If you use the sub-document tagging element to insert a document, the whole sub-document should be rendered (inside the master document) only without headers and footers. Is the other content of the sub-document rendered correctly? Can you please send us the template and the sub-document? If you have a workable simple project which we can use to reproduce the issue directly, please send it as well. (Note that you can attach files to the posts)
Thanks, Jure Leskovec
jrousselle posted this 14 January 2014
Yes the other content (fields) is rendered correctly but not the picture ...
I attach master and sub-document.
Thanks
11 Points
jles posted this 14 January 2014
Thanks for the sent material. This was bug that we have fixed. The fix is already available in the form of a new public release which can you can download from our standard download location. Please uninstall the old version and download and install the new one.
Please let me know if everything works as expected.
Cheers, Jure Leskovec
jrousselle posted this 15 January 2014
Hi
Thanks but now I have an error :
L'exception System.TypeInitializationException n'a pas été gérée Message="Une exception a été levée par l'initialiseur de type pour 'Docentric.Word.DocumentGenerator'." Source="Docentric.Word" TypeName="Docentric.Word.DocumentGenerator" StackTrace: à Docentric.Word.DocumentGenerator..ctor(Object defaultDataSourceValue) à ConsoleApplication1.Program.Main(String[] args) dans C:\Dev\test\ConsoleApplication1\ConsoleApplication1\Program.cs:ligne 166 à System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args) à System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) à Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() à System.Threading.ThreadHelper.ThreadStartContext(Object state) à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) à System.Threading.ThreadHelper.ThreadStart() InnerException: Message="The Docentric.Word product is not properly installed. Please reinstall the product" Source="Docentric.Word" StackTrace: à Docentric.Word.DocumentGenerator..cctor() InnerException: System.ComponentModel.LicenseException Message="The product is not properly installed. Details: Impossible de trouver une partie du chemin d'accès 'C:\Documents and Settings\All Users\Application Data\Docentric\Toolkit\license.lic'." Source="Docentric.Shared" StackTrace: à Docentric.Licensing.DocentricLicenseProvider.GetLicense(LicenseContext context, Type type, Object instance, Boolean allowExceptions) à System.ComponentModel.LicenseManager.ValidateInternalRecursive(LicenseContext context, Type type, Object instance, Boolean allowExceptions, License& license, String& licenseKey) à System.ComponentModel.LicenseManager.ValidateInternal(Type type, Object instance, Boolean allowExceptions, License& license) à System.ComponentModel.LicenseManager.IsLicensed(Type type) à Docentric.Word.DocumentGenerator..cctor() InnerException:
I use an evaluate version (resting 24 days).
11 Points
admin posted this 15 January 2014
Can you please specify the full exception (message + at least the beginning of the stack)? Does this error occur in Add-In or in Visual Studio when running the project that incorporates Docentric Toolkit?
21 Points
Exception occur when I call : DocumentGenerator dg = new DocumentGenerator(d);
It's in Visual Studio when I test my programm.
11 Points
Stacktrace :
11 Points
Message : "The Docentric.Word product is not properly installed. Please reinstall the product"
Thanks !
11 Points
In the last release we switched back in license validation for the engine (Docentric.Word.dll) and we obviously introduced an issue that is not manifested everywhere. I will immediately remove it out and release it so you won't be wasting your time. Please wat for another 20 minutes, I'll be back to you and let you know when the fix is ready to download. I'm really sorry for the inconvenience.
The license validator checks for the license existence at the specified path that it obviously could not find. May I ask you to check if the path exists and if everyone (or at least the process) has permission to access it? And also which OS version you have. I would be very grateful for your help.
21 Points
No problem :)
The path doesn't exist on my server (where my programm run) because I just copy all dll (I don't execute the setup on my server)
I only execute setup on developper computer (Windows 7 PRO SP1) for install addin
11 Points
jles posted this 15 January 2014
Thank you very much for this info! So if I understand you correctly, this error occurs in the product environment. I hope this will help us resolve the issue.
Anyway, the new release is ready for download. Please repeat the uninstall/download/install procedure and let me know if everything works now.
Thanks again, Jure Leskovec
Oh, I forgot to ask you another thing. Did you run your application via Visual Studio on the production server or at least attached a debugger (Visual Studio) to the process running Docentric Toolkit? Because this would require full installation of Docentric Toolkit on the production server as well.
Good news : - the bug is closed (images in subdocument are diplayed) - the error is corrected !
Very Thanks, it's perfect. For info I use XML to benefit from the power of XPath. I begin my test but i find your product very interesting. I think PDF support would be an advantage.
I use dll on an integration server without MSO. On real server I understand i must install full version.
11 Points
I'm glad to hear everything works.
We are aware that lack of PDF output is a serious limitation for our product. But note that PDF output is a top priority feature that will be introduced in the next major release. If there was a PDF support, would you use it right away or you don't need it seriously right now?
In my opinion most of the developers (our customers) use ".NET Objects" as their data sources, but this is probably because the majority of them create special classes objects that already have coirrectly shaped data and are suitable for binding in templates. On the other hand, XML data sources can handle dynamic situations much better, thanks to XPath, what you have obviously already found out by yourself.
Please come back any time you encounter an issue or have a technical question regarding the toolkit. And thanks for all your help!
Cheers, Jure
I use it right away because my application need it.
At the same time I test your solution, I'm looking for a converter Docx to Pdf :) !
11 Points
We are about to release our new product Cloudox which is Docentric Toolkit in the cloud. But this service also has the Convert operation which will definitely serve your purpose. We (will) give this functionality to our customers/users for free (for a limited number of docs per month) until we develop intrinsic PDF support in Docentric Toolkit. Let us know if you need a test account for Cloudox to test the functionality.
jrousselle posted this 07 March 2014
I am interested by this test !
You know when you would develop intrinsic PDF support in Docentric Toolkit ?
11 Points
jles posted this 07 March 2014
Hi Jeremy,
I will send you the Cloudox test account to your email soon. Regarding the PDF output support, the feature will be introduced with Docentric Toolkit 2.0 that is scheduled to be released at the beginning of July. If you want to have access to early alpha or beta versions let me know.
