Field on Textblock
dave posted this 06 March 2013
When I add a field on a text block, it doesn't seem to work. In the final document the definition of the binding is showed, instead of the data from the datasource.
Greetz,
Dave
0 Points
2 Comments
jles posted this 07 March 2013
Hi Dave,
What do you mean by a 'text block'? If possible, could you please send the template (it can be a simplified version of your production template). This way I will be able to see exactly what you are doing.
Thanks,
Jure Leskovec
jles posted this 10 March 2013
Solved via Support e-mail.
New feature add in the release 1.3.5.23315:
Enabled templating of shapes (Text Box), comments, footnotes and endnotes. Now it is also possible to put tagging elements inside document parts other than body, header and footer.
Our 231341 members have posted 347 times in 103 discussions
