Document.Load throws exception
JB posted this 03 February 2015
Hello,
here is our code for generating documents:
public class BobTheBuilder
    public void GenerateReport(byte[] inputTemplate, string outputDocument, object data, SaveOptions saveOption)
        using (var inputTemplateStream = new MemoryStream(inputTemplate))
        using (var tmpDocumentStream = new MemoryStream())
        using (var outputDocumentStream = new FileStream(outputDocument, FileMode.Create))
            this.GeneratePdfReport(inputTemplateStream, tmpDocumentStream, data, saveOption);
            var document = Document.Load(tmpDocumentStream);
            document.Save(outputDocumentStream, saveOption);
    private void GeneratePdfReport(Stream template, Stream report, object data, SaveOptions saveOption)
        var documentGenerator = new DocumentGenerator(data);
        documentGenerator.ElementInitialize += this.DocumentGeneratorOnElementInitialize;
        var result = documentGenerator.GenerateDocument(template, report, saveOption);
        if (!result.HasErrors) return;
        foreach (var error in result.Errors)
            Console.WriteLine(error);
    private void DocumentGeneratorOnElementInitialize(object sender, ElementInitializeEventArgs elementInitializeEventArgs)
The suggested workaround to update the Table of Contents in the document is to load the generated Document and Save it using the Document.Load() and Document.Save().
However this line:
causes the following exception: (formatting is a bit weird, sorry about that)
System.Exception was unhandled by user code HResult=-2146233088
Message=Style 'Normal' cannot be added to the document because a style with the same name already exists in the document.
Source=Docentric.Documents.ObjectModel StackTrace: at Docentric.Documents.ObjectModel.StyleList.InsertItem(Int32 index, Style item) at System.Collections.ObjectModel.Collection`1.Add(T item) at #=quEhVhX4UgtrL14nHWlNtfPKvADhaDW2LOIq2fqTCiHIgs5OhP3gf9LUPx$JaKmDVirVIqgzQZ90tsL7EGrDw==.#=qnhtwKI2KtSdxWYaiT$oitnK$Mm_bDD18nHX$Iq3$P78=(Style
=q6mojHLSkT2IP7xZaBAkawQ==, Style #=q7d4hLBnXmk2npWnacH5OOA==, Dictionary`2 #=q17Vohh$PVEjIiHiQUKSxuAOtrkhNZjXUCAGioZMVOUE=)
   at #=quEhVhX4UgtrL14nHWlNtfPKv_ADhaDW2LOIq2fqTCiHIgs5OhP3gf_9LUPx$JaKmDVirVIqgzQZ90tsL7EGrDw==.#=qMQ6_gR7dOi2J00gufex$dg==()
   at #=quEhVhX4UgtrL14nHWlNtfPKv_ADhaDW2LOIq2fqTCiHIgs5OhP3gf_9LUPx$JaKmDVirVIqgzQZ90tsL7EGrDw==.#=q2wDK3LTq5B4xt2FWBJecEA==(Stream #=qwoGEvXFmcI4PREI2uWPNEQ==)
   at Docentric.Documents.ObjectModel.Document.#=qqX8gJaBN$QNzpEVh9$xS$w==(Stream
=qo5AcTlWDQuACz7z9Lbuy2A==)
   at Docentric.Documents.ObjectModel.Document.Load(Stream stream)
   at WindwardPrototype.ViewModel.BobTheBuilder.GenerateReport(Byte[]
inputTemplate, String outputDocument, Object data, SaveOptions saveOption) in c:\Users\buttlaj\Documents\Visual Studio 2013\Projects\WindwardPrototype\WindwardPrototype\ViewModel\BobTheBuilder.cs:line 18 at WindwardPrototype.ViewModel.MainViewModel.GenerateDocument() in c:\Users\buttlaj\Documents\Visual Studio 2013\Projects\WindwardPrototype\WindwardPrototype\ViewModel\MainViewModel.cs:line 132 InnerException:
1 Points
2 Comments
admin posted this 03 February 2015
Could you please send/attach the resulting document from the GenerateDocument method, the one you then try to load with the Document.Load method?
Thanks, Jure Leskovec
21 Points
jles posted this 09 February 2015
This issue has been fixed and is available in the form of a public release.
Our 231228 members have posted 347 times in 103 discussions
