Docentric Table of Contents Example
AxaMatrix posted this 14 April 2016
Do you have an example of how to program the Table of Contents? We have designed a template to use ToC and have attempted to use Document.Load() to try to open and update the ToC, but we get the same Exception as the "Document.Load throws exception" discussion. We have tried using the lastest version as well. Any help will be greatly appreciated.
12 Points
6 Comments
admin posted this 20 April 2016
Documents with TOC are supported by DOM and Document.Load should work as expected. It seems like an issue that needs to be fixed. Could you please attach the offending document to your post so that we can reproduce the issue on our side? In case you wouldn't like to share the document publicly on this forum, you can also send it to our support email address: support at docentric dot com.
Thanks, Jure Leskovec
21 Points
AxaMatrix posted this 21 April 2016
We have uploaded the template
12 Points
jles posted this 24 April 2016
We have found and fixed the issue. Please download this non-public release containing the fix: http://www.docentric.com/downloads/DocentricToolkitSetup4.0.exe
And please let me know if the release fixes the problem on your side.
AxaMatrix posted this 28 April 2016
We are receiving a new error when we use Document.Save():
Method not found: 'Double Docentric.Pdf.Drawing.XGraphics.MeasureStringWidth_DT(System.String, Docentric.Pdf.Drawing.XFont)'.
12 Points
jles posted this 13 May 2016
We were unable to reproduce the issue using the attached document. Could you please provide the document that causes the error. Also, could you double check that you are using the new assembly?
Thanks, Jure
AxaMatrix posted this 19 May 2016
Thanks Jure. it works. reference problem
12 Points
