Bar Code is not showing with label on bottom
MohanRaju posted this 20 June 2017
I am able to generate Bar code using default template , but i need Bar code with bottom label. In the link http://ax.docentric.com/label-design-ms-word-docentric-ax-designer/, we see the label needs to be manually placed under the bar code but do we have any setting which shows the label by default?
1 Points
1 Comments
jles posted this 20 June 2017
Hi Mohan,
Thank you for your inquiry. BARCODE tagging element can currently only render the graphic part of the bardcode, not the label under it. But you can always add a TEXT tagging element below the barcode to render the text separately.
Best regards, Jure
